Can I use "port security" with snmp?
Apr 3rd, 2008
I have catalyst2950 switch.
I want bind MAC address to port with port security:
switchport port-security
switchport port-security violation shutdown
switchport port-security mac-address XXXX.XXXX.XXXX
Can I do this with SNMP? What objects I need to change and how? Post the example please.
I am using net-snmp(snmpset).
miheg Thu, 04/03/2008 - 05:25
On a cat2950? didn't know they supported that.
Using snmp here is not very efficient.
Port security automatically learns and remembers the first mac address. No need to configure that.
I rather spend time on collecting the syslog messages from ports going disabled.
Enable an errordisable timeout so that after say 5 minutes things work again until an other mac address comes along.
And then investigate the ports going in error disable and remove the hubs.
