ANIServer failed to run on CW LMS 2.6
Apr 3rd, 2008
ANIServer failed to run problem.
Restart of ANIServer process, Deamon manager, or CiscoWorks server does not help.
Before this problem, for some time, we had java.exe failed errors when connecting to CW server.
We upgraded Common services from 3_0_5 to 3_0_6 and Campus Manager from 4_0_8 to 4_0_10. Still the same problem.
Joe Clarke Thu, 04/03/2008 - 07:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like your C:\PROGRA~1\CSCOpx\campus\etc\cwsi\ANIServer.properties file is corrupt. Please post it.
smandrapa Fri, 04/04/2008 - 01:40
Here are ANIServer.properties, and ANIServer.properties.orig files.
Joe Clarke Fri, 04/04/2008 - 10:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Your ANIServer.properties file is severely corrupted. Attached is a good one which will load. You will need to go back through your Data Collection and User Tracking settings in the GUI to make sure all of the configurable options are what they need to be.
The fix this, shutdown dmgtd, then copy this ANIServer.properties to C:\PROGRA~1\CSCOpx\campus\etc\cwsi. Then restart dmgtd.
