Power consumption and BTU values for Cisco equipment
Apr 3rd, 2008
Hello
In our company, we are designing a new datacenter. To define the total electrical and cooling power we need to know the power consumption and the BTU for all our Cisco equipment. Is there a way to find these values within the Cisco website without looking up all the different equipment? I can imagine that there is a tool somewhere where I can choose the hardware and I will get this figures.
Thanks a lot
Markus
Overall Rating: 5 (1 ratings)
guruprasadr Thu, 04/03/2008 - 05:09
HI Markus, [Pls Rate if HELPS]
Refer Link below for CISCO Power Calculator Tool:
http://tools.cisco.com/cpc/launch.jsp
The Cisco® Power Calculator enables you to calculate the power supply requirements for a specific Power over Ethernet (PoE) configuration.
Note: To access this Tool, you requrie Privileged Level Access. Contact: CISCO Support or nearby CISCO Partner for Help
Hope I am Informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
markus.albisser Thu, 04/03/2008 - 07:28
Hi Guru again.
Just as an input: It would be helpful if there will be all the Cisco equipment (also other switches, routers etc.) listed in the pull down field. Would that be an input for a next release of this tool?
Best regards
Markus
guruprasadr Tue, 04/15/2008 - 10:29
HI Markus,
Sorry for the late reply.
The question can be answered only by some CISCO Technical Team involved in Product Development.
Let's see if somebody answer.
Best Regards,
Guru Prasad R
