Add unencrypted non IPSec to PIX
Apr 3rd, 2008
I was hoping I could get some help from the group on the following.
I'm working with a PIX that is set up to only do IPSec connections via the internet. I am trying to add the ability to make unencrypted non IPSec connections to the internet.
Below is a copy of the existing PIX config and what I tried adding to get an unencrypted connections to the internet.
Public IP addresses are not real (2.x.x.x & 6.x.x.x)
Seems like this should be simple. I must me missing something. I am attempting to use PAT (the 2.100.211.40 address)
Michael Hurley
husycisco Thu, 04/03/2008 - 10:13
  • Gold, 750 points or more
Hi Michael
no access-list internal_net_access_in extended permit ip 10.11.28.0 255.255.255.0 object-group CoLo
no nat (outside) 0 access-list outside_nat0_outbound
nat (internal_net) 0 access-list outside_nat0_outbound
nat (internal_net) 1 0 0
global (outside) 1 interface
no access-list outside_access_in extended permit icmp 10.0.10.0 255.255.255.0 10.11.28.0 255.255.255.0 echo-reply log
no access-list outside_access_in extended permit icmp 10.0.20.0 255.255.255.0 10.11.28.0 255.255.255.0 echo-reply log
no access-list outside_access_in extended permit icmp 10.0.30.0 255.255.255.0 10.11.28.0 255.255.255.0 echo-reply log
no access-list outside_access_in extended permit icmp 10.0.40.0 255.255.255.0 10.11.28.0 255.255.255.0 echo-reply log
no access-list outside_access_in extended permit icmp 10.0.50.0 255.255.255.0 10.11.28.0 255.255.255.0 echo-reply log
access-list outside_access_in extended permit icmp object-group CoLo 10.11.28.0 255.255.255.0 echo-reply log
no access-group internal_net_access_in in interface internal_net
clear xlate
mvhurley9 Thu, 04/03/2008 - 10:47
Huseyin,
Are you suggesting I remove the IPSec stuff just for testing purposes? I may be able to do this.Eventually we need to have some traffic use IPSec and some traffic go directly to the internet.
Michael
mvhurley9 Thu, 04/03/2008 - 14:38
I am looking at Cisco Document ID 82020 that covers split tunneling. They mention the following: In order to set a split tunneling policy, issue the split-tunnel-policy command in the "group-policy configuration mode".
Can someone tell me how/where to get into the group-policy mode.
Michael
husycisco Fri, 04/04/2008 - 03:15
Michael,
My above suggestions are not for removing IPSec. It makes the traffic originated from 10.11.28.0 255.255.255.0 and destined to object-group CoLo flow through the IPSec Tunnel, and rest will flow through outside interface without IPSec directly to internet.
Split-tunneling is actually for Remote Access, and has no relationship with your issue.
