C3750 DWDM
Apr 3rd, 2008
Is is possible to have dwdm connectivity on the 3750 series switches ?
The only wdm sfp connector available for the 3750 is CWDM.
I was told that all you need is a Fiber GE connection on the Switch.
Any advice appreciated.
Paul
Tom Randstrom Fri, 04/04/2008 - 06:40
According to the attached release notes and Q&A, the DWDM SFPs are supported on the 3750 with the proper software load.
Q&A
<http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5532/prod_qas09186a00801eb822.html>
Release Notes
<http://www.cisco.com/en/US/docs/switches/metro/catalyst3750m/software/release/12.2_44_se/release/notes/OL14631.html#wp56800>
Hope this helps.
Tom
