Cannot see MAC address of PC's WLAN NIC
Apr 3rd, 2008
Hi everybody,
I have a PC with a GigabitEthernet LAN NIC and a WLAN NIC.
The PC is connected to a Catalyst 3560 (switch A) and is also registered in an AP AIR-AP1231G-E-K9 connected to another Catalyst 3560 (switch B). Switch A and B are connected.
If I check the MAC address table of switch A and B, I find the PC's LAN NIC MAC address but not the PC's WLAN NIC MAC address.
As a result, the L2 frame directed to PC's WLAN NIC MAC address are flooded to all the ports of the switch.
Why this MAC address is not learnt by the switch?
Thanks a lot
Stefano
Overall Rating: 2 (2 ratings)
Richard Atkin Thu, 04/03/2008 - 11:34
Presume from the partcode, that you're not running lightweight.
Have you verified that the AP is correctly connected to the network (VLANs, Trunks, etc...) and that the client successfully associates and authenticates with the Access Point?
Scott Fella Thu, 04/03/2008 - 18:23
You should see all the clients mac address associated on that ap on the switchport the ap is connected to. If you do a show dot11 association, do you see the mac address?
s-durando Fri, 04/04/2008 - 00:23
There are two client associated and authenticated with che AP and I can see their MAC address in the 'show dot11 association' output.
Unfortunately in the Catalyst connected to the AP I can see only one of these two MAC addresses
Stefano
s-durando Fri, 04/04/2008 - 00:20
Yes, the AP is correctly connected to the Catalyst with a trunk that carries all VLANs.
Moreover, at this moment there are two clients associated and authenticated with the AP but I can see only one of these two MAC addresses in the MAC address table of the Catayst
Stefano
Scott Fella Sat, 04/05/2008 - 07:39
So if you get the mac address of the wireless card and do a show mac-table | in
there is no entry in the switch the ap is connected to?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
