QOS Question - Showing 1,000,000 discards per day
I have a DS3 terminated with 7206VXR-GE2 on each end. The circuit is purely to replicate traffic between 2 systems. So there are basically only 2 hosts and 1 protocol. What can I do to help reduce or eliminate all of these discards. I have no QOS on the circuit. Would shaping help signal the sending host to slow down and reduce these discards?
Thank you for your help.
royalblues Thu, 04/03/2008 - 08:14
Is there any problem you are facing with the replication or you are just interested in the getting rid of the discards?
If you do configure shaping, you will not see the discards but it is quite possible that they show up as delayed bytes.
what is the IOS you are running?
Narayan
Serial1/0 is up, line protocol is up
Hardware is M1T-T3+ pa
Description: DS3 Circuit
Internet address is 10.255.254.6/30
MTU 4470 bytes, BW 44210 Kbit, DLY 200 usec,
reliability 255/255, txload 3/255, rxload 1/255
Encapsulation PPP, LCP Open
Listen: CDPCP
Open: IPCP, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 3d03h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2354497
Queueing strategy: weighted fair
Output queue: 0/1000/64/2354497 (size/max total/threshold/drops)
Conversations 0/72/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 44210 kilobits/sec
5 minute input rate 223000 bits/sec, 314 packets/sec
5 minute output rate 602000 bits/sec, 324 packets/sec
208856856 packets input, 1621576644 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 parity
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
261926945 packets output, 1797784893 bytes, 0 underruns
0 output errors, 0 applique, 0 interface resets
0 carrier transitions
rxLOS inactive, rxLOF inactive, rxAIS inactive
txAIS inactive, rxRAI inactive, txRAI inactive
Joseph W. Doherty Thu, 04/03/2008 - 17:48
About .9% drop. That normally isn't considered that bad if the link is being filled.
I see Queueing strategy: weighted fair. How is the interface configured to obtain WFQ?
In this snapshot of interface stats, the interface isn't very active. Have you seen it at much higher load rates?
What's the CPU history like? (show proc cpu history - supported?)
What do your buffer stats look like? (show buffers)
