Select default routes in BGP
Apr 3rd, 2008
My company has 2 large sites with internet access and 2 small sites with NO internet access. All of the sites are connected via an MPLS cloud. I would like to inject the default routes from both large sites into the BGP MPLS cloud and configue the 2 small sites to pick one as primary and the other as secondary. I have attached a network diagram and here are the details:
SITE A:
-Pick Site B's default route as primary
-Pick Site D's default route as secondary
SITE B:
-Has internet connection
-Default route is injected into EBGP via a static route, redistribute into eigrp and advertise to EBGP via the network 0.0.0.0 command
SITE C:
-Pick Site D's default route as primary
-Pick Site B's default route as secondary
SITE D:
Does anyone have any suggestions or bgp config examples on how to accomplish this?
Giuseppe Larosa Thu, 04/03/2008 - 08:54
  • Hall of Fame,
    Founding Member
just one question are you sites inside a MPLS VPN and you manage the CE routes or you have control of PE/LSR routers at each site ?
If this your case you can change the weight or the local preference of incoming BGP advertisements to provide the selection hierarchy you want.
To be selective a route-map could be used and you can set the weight or the local preference for prefix 0.0.0.0/0 (using a prefix-list to specify it) and using also a match ip next-hop acl where you specify the site A or site B PE/LSR loopback address
Instead, if you are in a MPLS VPN and you can control only CE routers you have to ask your provider to do this job for you on the
PE routers of site A and B.
Hope to help
Giuseppe
dd99onedd Thu, 04/03/2008 - 10:49
I can only control my CE routers. Thanks for the post.
