IP Communicator thru PtP no talk path
Apr 3rd, 2008
I have several IP Communicators deployed all of which connect via Cisco VPN client to a PIX at our main location without a problem.
We recently deployed a PIX 501 for a point to point VPN. Behind this an IP Communicator can connect to the local CCM and get its load and extension and dial tone. when dialing from it to extensions it rings but upon answer there is dead air.
Any ideas?
Andy
gogasca Thu, 04/03/2008 - 10:52
  • Green, 3000 points or more
check the Audio settings in IPC to make sure we are sending the audio using the proper interface.
An sniffer capture can show you the IP addr and port for UDP\RTP streams
