Upgrade from CAT OS to IOS.
Apr 3rd, 2008
Am new to 6509 and 4509 switches,
I have a 6509 and 4509 CAT OS switch which i would like to upgrade to IOS,could any of give me a step by step procedure on how i would go about this.
Thanks a lot.
Urfan Khaliq Wed, 04/09/2008 - 19:25
As well as the procedure to actually upgrade your system to IOS you will also need to think about converting your current config from CATOS to IOS...
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a0080816fbc.shtml
This is a converter tool which is quite useful, you enter CATOS commands to learn the IOS equivilant, however do double check the results also.
Rate if helps
Urfan
