How do I clear IP traffic stats?
rblankers
2621 running IOS 12.0(7). I just disbled ppp fragmentation and want to clear the IP traffic stats so I can verify that fragmentation has stopped... anyone got the command?
If you are running IOS version 12.4(2)T or later you can use the command 'clear ip traffic' to reset ip traffic statistics. Unfortunately, in the older versions the only way to reset the stats is by reloading the router.
Clear IP Traffic CLI:
The Clear IP Traffic CLI feature introduces the clear ip traffic command to clear all IP traffic statistics on a router instead of reloading the router.
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t2/ht_clrip.html#wp1047580
Sundar
5 Replies 5
did you try "clear counters" ?
I did, but that doesn't clear the IP traffic stats.
Sundar
thanks, that's kind of what I thought.
rblankers
I used the command 'no ppp multilink fragmentation', but still seeing fragments. Tried restarting the interface but no change. Do I need to reload the router for this to take effect?
