Port forwarding on PIX 515
Apr 3rd, 2008
I am trying to turn on port forwarding for TCP and UDP for a specific port (22222) from a static IP address (outside) to an internal static IP address.
I cannot get this working. I tried using the ASDM and it didn't work there either.
acomiskey Thu, 04/03/2008 - 11:55
  • Green, 3000 points or more
static (inside,outside) tcp interface 22222 netmask 255.255.255.255
static (inside,outside) udp interface 22222 netmask 255.255.255.255
cadstillo Thu, 04/03/2008 - 12:00
I assume that (inside,outside) is either or correct, depending on the need?
This is what it should look like?
static 64.233.167.99 tcp interface 22222 xx.xx.xxx.xxx 22222 net mask 255.255.255.255
static 64.233.167.99 udp interface 22222 xx.xx.xxx.xxx 22222 net mask 255.255.255.255
Thanks for the quick response!!
acomiskey Thu, 04/03/2008 - 12:24
No, you actually type "(inside,outside)".
These are the names of the inside and outside interfaces. So yours may be different. If yours are named "inside" and "outside" then you would type exactly what I wrote before.
cadstillo Thu, 04/03/2008 - 12:26
Thanks for clearing that up. So how do I isolate the port forwarding on a specific public IP address?
acomiskey Thu, 04/03/2008 - 12:40
If you are using the public ip that is assigned to the outside interface then it would look the same as before...
If you want to use a different public ip you would simply replace "interface" with the ip address...
static (inside,outside) tcp 22222 netmask 255.255.255.255
static (inside,outside) udp 22222 netmask 255.255.255.255
cadstillo Thu, 04/03/2008 - 12:42
Excellent!! I will try this and see how it works!
rechard_david Tue, 04/08/2008 - 23:00
Dear Sir,
I just saw your message on forum that you told forwarding port on pix. So i would like to ask you that on ASA 5510 i uer forwarding port on ASA but it doesn't work this is command that i put in ASA,
-access-list 100 extended permit tcp any host 50.50.50.50 eq 5900
-static (inside,ouside) 50.50.50.50 5900 10.10.10.2 5900 netmask 255.255.255.255
Note: my interface Outside e0/0 IP address is :50.50.50.50
Could you verify for me please!!!!!
