block called name /number
balitewiczp
Level 2
Level 2
Is there a way to block called name / number from being sent out an mgcp gw on a per phone/line basis?
thanks
Jaime Valencia
unfortunately with MGCP that can only be set at the route pattern or translation pattern level.
you could create a RP for the phones you want to block so they use it.
javalenc
if this helps, please rate
java
Jaime Valencia
javalenc
java
yes, thats what I thought. thanks for the sanity check
