Allow callers to dial an extension during greeting
Reception greeting has "Allow callers to dial an extension during greeting" checked. When an outside caller is in the greeting and dials an extension, they hear "wait while I transfer your call" and then they are put directly into that extensions voicemail -- the phone never rings.
The subscribers extension under call transfer has "Yes, ring subscribers extension" marked. So, it seems like everything is configured correctly.
Unity 4.0(5)
Can this be changed?
Ginger Dillon Thu, 04/03/2008 - 13:10
Hi -
Would you check to see if an Alternate Transfer rule has been enabled for the subscriber? I wouldn't be surprised it is says Transfer to greeting.
ranpierce Thu, 04/03/2008 - 14:18
:-) Ginger has been looking at the EFT too much. It is enabled in the SA for subscribers and callhandlers both.
4.05 you are right only call handlers. However it is just not shown in the SA but it is still there. Changes are not supported. So if Ginger is right, then TAC needs to fix it.
Ginger Dillon Thu, 04/03/2008 - 14:39
Yep -
Randy is correct, I've been spoiled by the newer Unity functionality!! Check out the info here - "By default, the alternate transfer rule is enabled for subscribers. In earlier versions, subscribers only had one transfer rule. If you are upgrading to Cisco Unity version 5.0(1), the existing values of subscriber transfer rules are retained as their alternate transfer rule." Sorry about the mis-information! If I may include something else that came to mind, could the other user's phone be forwarded to voicemail?
