Pix 515 VPN issues
Answered Question
Apr 3rd, 2008
We are trying to give remote client access to a server on inside interface. We have read alot of similare topics, but still is not working. Can someone please take a look at our configuration and let us know what we are doing wrong?
Our int are as follows:
outside = 204.222.162.0
inside = 192.168.1.1-254
DMZ = 204.222.161.0
Correct Answer by husycisco about 9 years 3 months ago
Hi Stefanie,
Assuming that you have a VPN connection, as you mentioned in your topic title, a static would not solve the issue. Please attach your config.
Correct Answer by fortis123 about 9 years 3 months ago
you need to have a static nat translation for the internal server.
static(inside,outside) netmask 255.255.255.255 0 0
Then create an access-list to allow access to the the host (public ip) with port..
ex:
access-list out_to_in permit tcp any host 1.1.1.1 eq telnet
Apply the ACL to outside interface.
hth
thank you
MS
Overall Rating: 5 (2 ratings)
Correct Answer
fortis123 Fri, 04/04/2008 - 09:27
ex:
hth
thank you
MS
Correct Answer
husycisco Fri, 04/04/2008 - 09:31
  • Gold, 750 points or more
Hi Stefanie,
