JORGE RODRIGUEZ Fri, 04/04/2008 - 18:10
  • Green, 3000 points or more
Driss, first you will need Security Plus license for DMZ support on ASA5505 models, with base license you will not be able to implement DMZ.
Once you upgrade license to Security plus and ready to configure DMZ, the access from higher security level in the case of inside sec level 100 is granted to lower security level no acls needed up to here. From DMZ to access inside hosts acl is needed. Read the link bellow for fruther reference .
http://www.cisco.com/en/US/docs/security/asa/asa80/getting_started/asa5505/quick/guide/dmz-5505.html
Rgds
Jorge
