Does IOS support working as ipsec client with xauth?
Apr 3rd, 2008
I'm trying to setup ios to connect to a third-party vpn gateway, that gateway need xauth authentication by sending a mode-cfg packet after phase1 finished, how can I make IOS respond that packet with a local username/password?
Currently ISAKMP debug shows "Unknown Input IKE_MESG_FROM_PEER,IKE_CFG_REQUEST" error when it received that mode-cfg packet.
ivillegas Wed, 04/09/2008 - 12:49
If you want router to use X-Auth you will have to change the mode to aggressive. Change this and check if this works.
hansyin Sat, 04/26/2008 - 22:02
you mean changing mode in IOS? I remember IOS will always try to use main mode and only try to use aggressive mode when main mode failed. Is there a command to force IOS to use only aggressive mode? what is it?
