CSM-Content Switching Module
Apr 3rd, 2008
Hi All,
How to shutdown Content Switching Module in Cat 6500 switches ? I want to shutdown only CSM-Module without disturbing Chassis.
Can anyone please send me the command on that ?
Highly appreciate your valuable reply.
ciscocsoc Fri, 04/04/2008 - 00:15
  • Silver, 250 points or more
Assuming you are using IOS, you can power-down a module in a 6500 chassis using the command
"no power enable module " in global config mode where is the slot number of the CSM.
If you are using CatOS then the command would be:
"set module power down "
The CSM should be hot-swappable so you should be able to just pull it out of the chassis, but I think that is a bit vicious if you only want to shut it down.
Cathy
