Remote access VPN to a PIX 515E using certificates
Apr 3rd, 2008
Hi all,
I have configured a Cisco 515E PIX for remote access VPN connections using PSK as the authentication type. I would like to be able to add dual factor authentication so the users would require a certificate to VPN into the PIX. I can't find much doco on this topic can anyone point me in the right direction, I would rather configure it using cli but I have access to the asdm. The VPN is working fine at the moment with just the one authentication method.
Thanks in advance.
b.hsu Wed, 04/09/2008 - 13:23
  • Silver, 250 points or more
Higher level dual authentication is not possible as far as I know. But you can use virtual http command in combination with regular authentication .
matt.eason Wed, 04/09/2008 - 16:52
Not sure what you mean by higher level authentication, all I'm trying to do is to use a certificates and psk as part of the VPN authentication process, I cant find much help in the configuration guide.
