Web Filtering
shijomon scaria
Hello Sir, i have 300 systems inside my network, all those have web access also. Here my requirement is to block some specific web sites and also i want to log the deatils about the users who are trying to use those sites. Thank you.
chickman
Just to put this out there, you could use a free service to assist. Take a look at OpenDNS, www.OpenDNS.com. This will provide you with similar ability as variety of pay services. The downside to this, you will not be able to report on user-website use. It will though give you information about website attempts and such.
Just as an additional resource.
6 Replies 6
a.ajiboye
You can block access to web sites and logs reports about sites blocked or allowed through the firewall by implementing the filtering feature of Cisco firewall. This is done by integrating the Firewall with either the Websense or Secure Computing web filtering software.
Can it be done with just Pix or ASA?
The answer is a NO unless you are willing to
buy Websense or N2h2 (or whatever they call it now) as the previous poster say.
Can it be done with other firewall vendors and
NOT requiring a 3rd parties software such
as Websense or N2H2?
The answer is YES if you use checkpoint
firewalls. You can block specific sites by
domains and with URI resource logging, it
will meet your requirements.
CCIE Security
Thank you all.....i hv one more doubt is there, we are having a Sonicwall 2040 pro is in our network, we want to enable url blocking in it, sonicwall permits url blocking by itself. Is it possible to over ride this blocking rule by some proxy softwares...??
chickman
