IPsec Tunnel Private-to-Private network just goes one way
Apr 4th, 2008
Hi there!
First time Cisco setup for me, trying to setup a VPN between headquarters (peer 100.1.1.1, internal network 192.168.2.*) and a branch office (peer 200.1.1.1, internal network 192.168.1.*).
I followed this guide (minus the static NAT): http://cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080094634.shtml.
What works:
- pings work either way;
- http works either way;
- windows file sharing works either way;
What does not work:
- remote desktop works going from headquarters to branch office but not viceversa;
- ftp works only from headquarters to branch office but not viceversa.
Router configuration for both offices is attached. Any help is greatly appreciated. IPs are changed for security.
Overall Rating: 2 (1 ratings)
istvanhoka Mon, 04/07/2008 - 06:44
After reading the suggested doc about fragmentation, I adjusted the both the MTU and TCP MSS to 1300. There was no change in the behaviour.
I am attaching the updated configurations.
