Apr 4th, 2008
Dear sir,
Kindly let us know there is any router which will support the data rates of 33.6 kbps and 44.8 kbps at the earliest.
plz give me the data sheet
didyap Thu, 04/10/2008 - 10:29
Data rates mean Bit rate it depends on Interfaces which are using in the Router and also depends on Bandwidth.
For example, The bit rate of 100 Mbit/s of an Ethernet 100Base-TX physical layer, The bit rate 64000 bit/s of one
ISDN B channel.
