Network Management: Archive purge not working
Apr 4th, 2008
Also Posted on - Mar 18, 2008, 6:09am PST
LMS - 2.6
RME - 4.0.6
A brief of logs under rme\jobs\ArchivePurge\1066.x'
(log files: log and log.1-4)
PURGE SETTINGS: ByVersion = true ByAge = false PurgeLabelledFiles = false
number_of_versions 7
info-> handleMultiDeviceExecution,149,Completed executeJob(), updating Results
info-> getNumCyclesToPoll,1018,getNumCyclesToPoll Function Started.
info-> updateMultiDeviceExecResults,781,Awaiting Job results: req Id = 0 Poll time = 5708 min(s)
debug-> updateMultiDeviceExecResults,782,Total No. of devices = 7611 ,numPollCycles 68499 ,Poll Time(Min): 5708
debug-> Stop Job called by Daemon Manager
debug-> CancelJobExecution Started:
info-> 897,Could not get results for 7611 device(s)
debug-> 919,Setting results for Fetch/Purge Job...
debug-> 948,Message : Unable to get results of job execution for device. Retry the job after increasing the job result wait time using the option:Resource Manager Essentials -> Admin -> Config Mgmt -> Archive Mgmt ->Fetch Settings Status : 2
The issue has been there for few months now, I cant remember any change that resulted in this.
>> It would be helpful to see the dcma... by jclarke - Mar 18, 2008, 9:07am PST
Posted by: jclarke - Customer Support Engineer, CISCO SYSTEMS, CCIE - Mar 18, 2008, 9:07am PST
It would be helpful to see the dcmaservice.log with ArchiveMgmt Service debugging enabled.
vijay sanwal Fri, 04/04/2008 - 05:38
Attached dcmaservice.log twice, but I dont see them here!!!!
Joe Clarke Fri, 04/04/2008 - 10:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Make sure once you upload the file, you click the Attach button, then post your comment.
Joe Clarke Sun, 04/06/2008 - 07:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There doesn't appear to be anything wrong with the archive. Enable ConfigJob debugging under RME > Admin > System Preferences > Loglevel Settings, then wait for another purge job to run, and post the job log.
