ANIDbEngine running high CPU
Apr 4th, 2008
My ANIDbEngine process is running about 44% CPU usage and I'm not sure why. Also, when I try to open topology groups they are taking a very long time to filter results. Why would the anidb process be running so high? and could it affect TG's? or are these separate issues?
sirbaughmf Fri, 04/04/2008 - 08:54
My biggest issue is that anything I do in Campus is very slow, opening topology groups from clouds, from folder, opening View Devices, etc. This is taking several minutes, I have three servers using SSO, the two slaves are showing the problem above, the Master is fine. Could this be related to SSO and authorization?
sirbaughmf Thu, 10/01/2009 - 07:41
I have upgrade to LMS 3.1 and I am continuing to see high cpu utilization on the ANIDbEngine process. Any thoughts would be greatly apprecitated.
