LMS 3.0 & Catalyst 6009 with CatOS 8.2
Apr 4th, 2008
We were running a device discovery at one of our sites and it appears that it somehow reloaded a Catalyst 6009 switch. It's a CatOS 8.2 switch with Sup1A module. It discovered all the IOS devices without any issues. This is the only CatOS switch at the site. Anyone else experience this behavior? Thank you in advance for all your help.
Joe Clarke Fri, 04/04/2008 - 10:52
What version of Common Services and Campus Manager?
As for the switch, you should check the config, and verify the SNMP credentials as well as make sure that if you have any ip permit lists defined that they allow the LMS server to poll the device.
