SPAN configuration on switch 2950
Apr 4th, 2008
I had enabled span port on the CAT 2950 switch to capture some traffic flows from a specific source port. I had connected Packet Shaper to the destination port.
For the source port, I had enabled for both (tx and rx) traffics.
My Packet Shaper report only shows inbound traffic. There is very little traffic detected on the outbound.
For your information, I didn't configured for ingress traffic on the destination port. Can this be the problem ?
How to report correctly for both inbound and outbound on the Packet Shaper. The Packet Shaper is configured in watch mode.
Please help.
Joseph
Joe Clarke Fri, 04/04/2008 - 10:55
But there is outbound traffic being detected? What is connected to the monitored port? If a multi-homed host, perhaps it is sending the reply traffic out of a different interface.
josephn Mon, 05/19/2008 - 23:59
Here is the snapshot after configuring the span port:
FastEthernet0/3 is up, line protocol is down (monitoring)
Hardware is Fast Ethernet, address is 000c.3087.e003 (bia 000c.3087.e003)
Description: Packetshaper(10.192.1.22) outside
MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
reliability 255/255, txload 27/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input 13w5d, output 00:33:21, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 10957000 bits/sec, 2336 packets/sec
553375 packets input, 260543901 bytes, 0 no buffer
Received 115206 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 98598 multicast, 0 pause input
1620444074 packets output, 800717686 bytes, 0 underruns
0 output errors, 0 collisions, 19 interface resets
Sorry, there is no traffic on the inbound.
regards,
Joe Clarke Tue, 05/20/2008 - 00:08
The monitor port should only have outbound traffic as the probe is most likely not generating any traffic of its own on that port. My previous questions were about the port being monitored.
josephn Tue, 05/20/2008 - 01:11
Here is the configuration for span on the switch:
monitor session 1 source interface Fa0/6
monitor session 1 destination interface Fa0/3
The source interface fa0/6 belong to vlan 10 as below:
10 VLAN0010 active Fa0/3, Fa0/4, Fa0/6, Fa0/19, Fa0/20, Fa0/22
FastEthernet0/6 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 000c.3087.e006 (bia 000c.3087.e006)
Description: Cisco2821 - 30M MetroE to Sinhub
reliability 255/255, txload 10/255, rxload 14/255
Last input 00:00:21, output 00:00:00, output hang never
Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 0
30 second input rate 5714000 bits/sec, 1156 packets/sec
30 second output rate 4122000 bits/sec, 979 packets/sec
131914122 packets input, 2655520328 bytes, 0 no buffer
Received 18729043 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 3582795 multicast, 3763 pause input
482803327 packets output, 885450104 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
Session 1
Type : Local Session
Source Ports :
Both : Fa0/6
Destination Ports : Fa0/3
Encapsulation: Native
Ingress: Disabled
Thanks.
Joseph
