routing through two VPN
dfcsystems
Hello anybody,
i have one simple VPN Routing question.
Can i have direct access to a lan which is connected over two vpn tunnel?
I attached a little description. There a client from the 1.1.1.0 lan want to have direct access to an ip from the 3.3.3.0 lan.
Is there some kind of routing which can make this possible?
Many thanks!
Robert
Jason Gervia
What you're basically trying to do is a 'hub and spoke' configuration with the ASA. This shouldn't be an issue, try following this link:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00804675ac.shtml
Thanks!
Jason Gervia
Thanks!
That's it.
Thanks a lot!
