CSM 3.1.1: restore backup error : Cleanup.pm missing?
Apr 4th, 2008
Hi folks!
I'm going to restorebackup data from a local CSM 3.1.1 server.
In the restorebackup.log file (follow in attachment) there is an error at line 1607:
Cleanup.pm not found
Infact this library is absent.
Anybody knows if this error could be gain DB inconsitance?
Any helps would be appreciate
Leonardo
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 04/04/2008 - 11:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This file should definitely be there under NMSROOT/databases/rmeng/scripts. In fact, it looks like a lot of things are failing in this restore. It could be your RME and Common Services installations are bad. I would certainly not trust any data that was restored to the system.
