Dual Site-to-site VPN links
Apr 4th, 2008
I am wanting redundancy in a site to site VPN. The central site has a reliable high speed link to the Internet. At the remote site I am looking at either dual PIXs, each going to a separate ISP or an ASA with dual links to separate providers. If I use two PIXs only one would be on at any one time.
Can I at the central site specify two remote peers to the same internal network at the remote site? If that is possible, how long would it take to detect a dead peer and send to the other?
tabdulla Mon, 04/07/2008 - 23:45
Ok,
You want to create aback up L2L connection,
So just add in the crypto map the ip address of PIX-2
(Central site)
crypto map mymap VPN
set peer 1.1.1.1 ------ PIX1
set peer 1.1.1.2 ------PIX2
So the VPN tunnel will use the first ip in the crypto map .if the first ip failed (detecting via DPD) the ASA will use the second IP.
Tariq
