Help with VPN between ASA and cisco 877
Apr 4th, 2008
Hi, I am trying to move a Cisco 877 that is happily connected to a cisco concentrator over a DSL to our Cisco ASA.
I changed the 877's peer to the ASA and went through the ASA's VPN wizard in the ASDM and the tunnel didn't come up.
I take it the local network is my LAN IP range and the remote network is the LAN IP range of the 877?
The VPN info on the 877 is:
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 5
crypto isakmp key abcdefg address 1.2.3.4
crypto ipsec transform-set CBSO_T_Set esp-aes 256 esp-sha-hmac
crypto map CBSO_Crypto_Map 10 ipsec-isakmp
set peer 1.2.3.4
set transform-set CBSO_T_Set
match address 101
The local IP range of the 877 is 172.19.15.0/24
My IP range on the inside of the ASA is 192.168.80.0/24
The peer IP of the 877 is 4.3.2.1
What should I add to the ASA is CLI or ASDM based on the above?
