Internal client can't establish VPN to external site thru 5505
Apr 4th, 2008
Total noob...My laptop can establish a vpn connection to a site when I am at home. Bring it to work, it can't establish thru the 5505. Can you tell me what I need to enable so I can VPN through it? I have searched and tried different things to no avail.
Jim
JORGE RODRIGUEZ Fri, 04/04/2008 - 16:19
  • Green, 3000 points or more
Hi Jim,
You do not specify which vpn client you are using to vpn from inside asa to outside but here are the most commonly used vpn clients examples you need to allow in asa5500.
add this to your global polciy for IPsec pass trhough ( Cisco VPN Client )
IPsec-Cisco-VPN-CLIENT
ciscoasa(config)# policy-map global_policy </p><p>ciscoasa(config-pmap)# class inspection_default </p><p>ciscoasa(config-pmap-c)# inspect ipsec-pass-thru </p><p>ciscoasa(config-pmap-c)#exit
For Microsoft PPTP
ciscoasa(config)# policy-map global_policy </p><p>ciscoasa(config-pmap)# class inspection_default </p><p>ciscoasa(config-pmap-c)# inspect pptp  </p><p>ciscoasa(config-pmap-c)#exit
please read these two links for background info.
Ipsec
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/i2_72.html#wp1668213
PPTP
http://www.cisco.com/warp/public/110/pix_pptp.html
Rgds
Jorge
JORGE RODRIGUEZ Wed, 04/09/2008 - 19:16
Jim, just following up.. are you all set with this or do you still have problems.
Rgds
Jorge
