Need MultiLink Frame Relay to work on 3640 router
Answered Question
Apr 4th, 2008
Have a 3640 with 64MB DRAM/16MB Flash running ver12.2-46a. The command "interface mfr 1" gets a invalid syntax. But, docs say feature intergrated in ver12.2(8)T. Pls help.
Correct Answer by Paolo Bevilacqua about 8 years 11 months ago
No problem and thank you for the explanation. If you need a very reliable memory vendor, contact me at the address present in my profile and I'll forward his email. Good luck!
Overall Rating: 3.6 (5 ratings)
Paolo Bevilacqua Fri, 04/04/2008 - 10:05
  • Hall of Fame,
    Founding Member
Hi, IOS "T train" releases have more features. Currently you have non-T, also called mainline.
Hope this helps please rate post if it does!
netspec-dineh Fri, 04/04/2008 - 16:04
Thanks for the advise. Unfortunately, all the IOS 12.3 "T" versions (which are ED) currently available for the 3640 require a flash of 32MB & 96MB of DRAM (i only have 16MB flash & 64MB DRAM). There is a "IP" version (min=64MB/16MB), but I understand that it does not have MFR capability. I have been told i must use IP Plus. So, I am checking about for memory upgrade now.
Joseph W. Doherty Fri, 04/04/2008 - 17:37
Won't help on memory, but if the minimum was noted as a 12.2(8)T, likely any 12.3(x) should work. I.e. shouldn't need 12.3(x)T.
netspec-dineh Fri, 04/04/2008 - 20:38
I have tried two 12.3 versions. First, the ver 12.3-26(GD). No "interface MFR" command was available. Then, tried the 12.3.14.T7(ED) and did see the "interface MFR (n)" command! But when entered, I still get that confounded invalid syntax error. Odd. I see the command, but it does not work.
Both these versions are the latest in thier folders. Note: I have to use the "IP" versions (-i-mz) as the "IP PLUS" versions (-is-mz) are over 16MB in size. Flash is only 16MB.
royalblues Fri, 04/04/2008 - 23:38
  • Green, 3000 points or more
I am not sure whether you need to use only MFR. The other way to do multilink over FR links is by creating virtual templates
eg. config
interface Multilink1
ip address x.x.x.x y.y.y.y
ppp multilink
ppp multilink group 1
interface Serial0/0/0:0
description " Framerelay PVC DLCI NO : 110 "
no ip address
encapsulation frame-relay IETF
load-interval 30
frame-relay lmi-type ansi
interface Serial0/0/0:0.1 point-to-point
frame-relay interface-dlci 110 ppp Virtual-Template1
interface Serial0/1/0:0
description " Framerelay PVC DLCI NO : 113 "
no ip address
load-interval 30
interface Serial0/1/0:0.1 point-to-point
frame-relay interface-dlci 113 ppp Virtual-Template2
interface Virtual-Template1
no ip address
ppp multilink
interface Virtual-Template2
no ip address
ppp multilink
Narayan
Paolo Bevilacqua Sat, 04/05/2008 - 03:33
  • Hall of Fame,
    Founding Member
I'd like to invite the person that has low rated Joseph and myself, to think better and the refrain next time, because the information given by both of us was 100% correct, either you like it or not.
netspec-dineh Sun, 04/06/2008 - 10:59
Hmm. Please accept my apologizes on that. This is my first post and I did not get that right. I do not know how to revise my error; sorry.
I did try the versions you both pointed out but found the only versions I could load with my limited memory did not have this needed feature. But, your pointers did get me on a good path to better understand what I am dealing with here and how to better use the Cisco tools...
So, I rated your last post high since I agree w/ your response re: that and in fact all your input has helped me better educated on accessing info about this stuff. Thx.
Correct Answer
Paolo Bevilacqua Sun, 04/06/2008 - 11:04
  • Hall of Fame,
    Founding Member
