Bandwidth on Ethernet
Apr 4th, 2008
I have a fast ethernet link to our ISP box. Our guranteed service is only 30Mbps.
What is the best way to configure our fast ethernet interface to limit traffic to 30Mbps?
Overall Rating: 5 (2 ratings)
Jon Marshall Fri, 04/04/2008 - 13:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You need to use shaping on your ethernet interface ie.
class-map match-all Class_Default
match any
policy-map WAN_Shape
class Class_Default
shape average 30000000
int fa0/1
service-policy output WAN_Shape
The ISP will probably police the traffic on their end but you are better off using shaping as it is a bit less drastic.
Jon
Joseph W. Doherty Fri, 04/04/2008 - 13:49
Another option, your Ethernet interface might support GTS, e.g. "traffic-shape rate 30000000". However, I endorse Jon's suggestion of using CBWFQ for future QoS options.
PS:
BTW: class-default is an implict class, you shouldn't need to define a class-map for it.
Jon Marshall Fri, 04/04/2008 - 14:41
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
"BTW: class-default is an implict class, you shouldn't need to define a class-map for it."
I know, i just thought it would be a better example rather than just a shape statement under the policy-map. Looking at it now you may have a point :-)
Jon
Joseph W. Doherty Fri, 04/04/2008 - 17:41
It is a fine example, postscript was directed to other readers, such as perhaps OP, who might not have been aware of the fact.
