IOS for Cat6509/Sup 720 with 7600-SIP-400= and SPA-2X1GE-V2
Apr 4th, 2008
Can anyone help to find correct IOS for Cat6509/Sup 720 with 7600-SIP-400= and SPA-2X1GE-V2 and SPA-5X1GE-V2? I could not find anything re this on Cisco site. There is whole bunch of info on 7600, but nothing on Cat 6500/Sup720.
Thanks, Olga
Overall Rating: 5 (1 ratings)
ogencheva Fri, 04/04/2008 - 19:34
Thank you very much for your response.Can you please share how did you come up with this specific release though? I am having a really hard time figuring it out. It is not mentioned in the specs or white paper on SIP/SPA, Software Advisor doesn't know about SIP/SPA as well. Do I have to go though all release notes to get the info? There must be an easier way.
Thanks again.
Edison Ortiz Fri, 04/04/2008 - 19:51
I spend quite a bit of time digging thru Release Notes so I found the reference without problems.
I recommend clicking on the feedback section for the Software Advisor page so the SIP/SPA can be documented properly.
A quick tip for navigating a Release Notes is by using 'search within your browser (Crtl+F)' for the keyword you are looking for. For instance, I was able to find the SIP/SPA you were looking for within 2 seconds by inputting the part number.
