How to stop a command - make it stop running (such as ping)
Answered Question
Apr 4th, 2008
Lets say I mess up and type 10000 instead of 1000 in an extended ping. Lets say I realize it only after the ping starts.
How do I make it stop?
Correct Answer by Richard Burts about 9 years 3 weeks ago
Michael
Generally the ctl shift 6 combination will stop these commands.
Rick
Overall Rating: 5 (5 ratings)
Correct Answer
Richard Burts Fri, 04/04/2008 - 14:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Michael
Rick
cybrsage Sat, 04/05/2008 - 05:39
Thank you!
I have found I have to hit the CTRL-SHIFT-6 combo twice in rapid succession for it to work, but I am using Hyperterm, so who knows.
Thank you so very much, that is a great tip.
Richard Burts Sat, 04/05/2008 - 09:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Michael
I agree that hitting the key stroke combination several times seems to be necessary in many instances - including times when I am not using Hyperterm.
I am glad that my answer was helpful. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read a response which resolved the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
Justin Brenton Fri, 04/04/2008 - 14:55
  • Silver, 250 points or more
Try this from the console.
hold down Ctrl+shift+6, release and then press x immediately. This may work depending on IOS
Justin
Richard Burts Fri, 04/04/2008 - 18:45
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Justin
The keystroke combination you give is right if you want to suspend a telnet session. But to stop an executing command you do not need the x. A Ctrl+shift+6 is enough.
Rick
Justin Brenton Sun, 04/06/2008 - 09:22
Thanks Rick, do you find it often do not work?
I often try to use this with no luck.
Justin.
Richard Burts Sun, 04/06/2008 - 11:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Justin
It may depend on what command you are trying to stop. I find that for ping and traceroute it is pretty effective (though it may take multiple entries of the key stroke combination). For other commands it may not be effective.
Rick
cisco_lad2004 Mon, 04/07/2008 - 05:20
  • Gold, 750 points or more
u can also set the break character by using "terminal escape-character Z" (I use z).
when I want to break a trace or oing, i simply hit z.
Sam
jake.epling Mon, 05/09/2016 - 06:50
I have a Cisco ASA 5505 and I just hit "q" to stop a task.
