Unity Connection Users get IMAP user credential check failed
Apr 4th, 2008
  • Cisco Designated VIP,
    2017 IP Telephony
I am trying to use TTS for Unity connection Users to access their email in exchange. However each time I try to test the user credentials I get "IMAP user credential check failed"
This is exhcnage 2003 and Unity connection 2.0.
The user alias exists in AD and I can login to echange using the user alias.
o-campbell Tue, 04/08/2008 - 13:07
Did you find a solution for this issue? I am running into the same problem. Thanks.
Ayodeji Okanlawon Wed, 04/16/2008 - 02:26
    2017 IP Telephony
Yes,
I managed to resolve this.
The problem was this: I enabled secure communication for TTS as documented in the Cisco Unity Connection Documentation.
However this did not work properly as my IMAP server (exchange) kept refusing connection.
I enabled advance login on Exchagne to know what the cause of this was..you can do the same..
Go to exchange....systems manager.....right click on your exchange server and click properties...click on diagnostics Loggin tab...under services select IMAPSvc..select all the category to your right and change their loggin levels to maximum....
Try Testing the connection again from Unity Connection..go the event viewer on your exchange and see the error you get.
If it complaints about secure channel...etc
Do the following to disable secure communication..
Go to your echange server..expand protocols...expand IMAP4..right click on default Virtual Server..properties..select access tab click on cummunication and un check require secure channel....Try again...
billriley19795 Tue, 09/16/2008 - 06:15
But if you do this you will send your username and password in clear text.
