aliebrahim Sun, 04/06/2008 - 07:46
Thanks but it doesn't say what the bugfixes are between the 746 and 747 builds.
karlyoun Sun, 04/06/2008 - 21:00
There is exactly one fix in this release, the one on the top.
Content Scanning Does Not Recognize Some Image File Types [Defect ID:40153, 39810]
This has been rarely sighted, so we didn't send a blanket announcement.
-karl
aliebrahim Mon, 04/07/2008 - 03:57
Thanks - this is now clear.
Another quick followup, when I did the upgrade from AsyncOS 5.5 to 6.0 it took a very long time (about 45 minutes total, IIRC, plus another 5 minutes to reboot).
Is the upgrade from 6.0.0-746 to -747 going to take as long? Or is this a "quick" upgrade that will take less than 5 minutes to install?
What kind of downtime should I plan for? (Our organisation only has a single Ironport which is our mail gateway)
igor.karasik Mon, 04/07/2008 - 05:41
From my experiense each IronPort upgrade take same time and it very depends on Internet line speed.
So, your upgrade from 6.0.0-746 to -747 will take about 45 minutes too...
