CSS11506 with Tomcat web server?
Answered Question
Apr 5th, 2008
Basically, I use SSL termination on CSS's SSL module and it seems no work for the web server using tomcat. The tomcat server insists to use http, not https. (The server always indicate client to query a URL with http head, not a URL with https head.)
Is it possible to change the behavior from CSS? My configuration is:
ssl-proxy-list ssl-slot3
ssl-server 19
ssl-server 19 vip address 10.1.1.19
ssl-server 19 rsakey testRSAkey
ssl-server 19 rsacert testCAcert
ssl-server 19 cipher rsa-with-rc4-128-sha 10.4.98.19 81
service test-backendserver-8080
ip address 10.3.3.29
protocol tcp
port 8080
keepalive type tcp
keepalive port 8080
active
content ssl-test-rule
protocol tcp
port 443
add service ssl-slot3-srv
active
content ssl-test-rule2
vip address 10.2.2.19
protocol tcp
port 8080
add service test-backendserver-8080
balance leastconn
active
Any comments will be appreciated
Thanks in advance
Correct Answer by Gilles Dufour about 9 years 2 months ago
I do not see the benefit of doing backend ssl if the frontend is cleartext.
Unless the CSS is on the clientside and you want to go accross the internet to the server.
In this case, yes, backend ssl could be a solution.
But verify first with a sniffer trace what is going on.
Gilles.
your tomcat server is either using absolute path (so link like http://.....) in this case the only thing you can do is modify the server, or the tomcat server is sending a redirect to the client to http://....
The SSL-mod can intercept the redirect and rewrite it to HTTPS.
You need to add a command 'ssl-server 19 urlrewrite 1 * sslport 443 clearport 8080'
A sniffer trace would tell you why the client keeps using http.
Gilles.
Overall Rating: 5 (2 ratings)
Correct Answer
Gilles Dufour Sat, 04/05/2008 - 06:23
  • Cisco Employee,
Gilles.
julxu Mon, 04/07/2008 - 01:15
if it is absolute path, can I use backend-ssl configuration to achive L5 load balancing (with stickness)?
Correct Answer
Gilles Dufour Mon, 04/07/2008 - 01:34
  • Cisco Employee,
Gilles.
julxu Wed, 04/16/2008 - 19:03
Gilles, thousands thanks your help.
Tomcat's native behavior is to generate
absolute URL's on all redirects. And that cannot be changed.
To fix it is to change configuration on tomcat to treat CSS as a proxy server.
