arp on routers
Apr 5th, 2008
Hi all, can anyone tell what devices routers should have as an arp entry, would it be mainly next hop routers, or anything that was pinged from the router ?
thotsaphon Sat, 04/05/2008 - 08:45
Hi carl,
Router should have every arp entries of devices that have ip connectivity to/from the router within the segment of router interfaces.
f.e. hosts send packets to router(default gateway) when the router replies those packets it needs layer3-to-layer2 mapping then send the packets back to hosts.
Hopes this helps
Thot
shiva_ial Sat, 04/05/2008 - 21:45
hi carl,
i beleive you are aware that every pc
communicates within network through mac address associated with network card
this address is fixed and there is no change in it
assuming packet travelling from one pc to another PC interconnected with routers
PCA---router1----router2------router3----PCB
packet travelling from PCA has mac address of this PCA along with interface address of router so that it can reach router(gets this through default gateway) now that packet reaches router, since the router uses only layer 3 information , it will figure out how to send to PCB and send to router3 using ip address which operates on layer 3,now the packet reached routers3-destination network
but it has to figure out where the host is located, so for that routers uses ARP entry
with this example routers3 will send a broadcast query to destination ip address to ask for mac address
after reply for particular ip address
(pc)router send to that mac address
so in summary arp used for LAYER3 -to -LAYER2 MAPPING
rate if it helps
rgds
shiva
