Reboot on Ping Failure on Cisco 877, 878, 871 Cisco Routers
jiaxiongxiao
Hi, we have a few 877, 878, 871 Cisco routers at our customer sites. The 877 runs on BDSL and the 878 runs on G.SHDSL. The issue is that occasionally those routers would drop the connections and often times, the only way is to manually reboot them. I know there is a auto enabled script that can reboot the routers in a specified time should it loses its connection. Can anyone let me know how this can be written and where can i find the source ?
I have the script but haven't tested it so won't know if it works or not. But if you have a script that works, kindly share with me. Thanks very much.
jsiow4@gmail.com
Joe Clarke
What version of code are these routers running?
