Comcast(Pri) DSL(Sec) failover
Apr 5th, 2008
I'm designing a network that has 3 satellite offices, VPN'ing to the HQ's building (approx 100 users total).
The three offices have a 8Mb Comcast cable internet connection and 1700 series routers.
The HQ building has a Comcast Cable internet connection and AT&T DSL connection.
I'd like to come up with a solution to offer automatic failover if the cable took a dive.
If it makes a difference, I'm considering wifi v/s dsl as a failover in case all cables are interrupted at the HQ building.
What type of router/firewall would you recommend?
Paolo Bevilacqua Sat, 04/05/2008 - 09:05
any cisco router with recent IOS software can do that, see example:
Note, because the VPN endpoints are "fixed", once a connection becomes unavailable, VPn goes down and you need secondary VPN, in practice this is better done with GRE tunnels and a routing protocol.
All in all is not an easy configuration so you may need to be supported by a qualified person to set it up.
