lamav Sat, 04/05/2008 - 15:51
  • Blue, 1500 points or more
"is it posible to have 1 Vserver farm with one virtual ip address on two switches not a single switch.??"
Absolutely, it's done all the time.
The technology would be seriously lacking if you couldnt, since its oftentimes deployed in a server farm environment that is architected for redundancy.
So, a typical scenario is one in which two server farm switches in a routed layer (access, distro, etc) run HSRP between them and have an instance of the v-server farm configured on each. One of the switches will act as the HSRP/SLB primary for all the v-server farms and the other will be the standby switch.
There's plenty more to be said about this. I am just giving you one typical example.
Read this link, it will help you.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4840g/12.0_10_w5_18/configuration/guide/4840red.pdf
Victor
