WCS and migration don't work for me. Help
Apr 5th, 2008
I tried to use the upgrade from WCS byt keep getting this error.
Resuls from Autonomous AP Migration Reports:
START: Detailed logging started at -> 04.04.2008_19.55.50
INFO: Telnet to device done.
INFO: Privilege level is equal to 15.
INFO: Setting vty line completed.
INFO: Dumped Environmental variables.
INFO: AP is supported for Upgrade process
INFO: IOS version is greater than or equal to 12.3(7)JA.
INFO: AP has MIC installed already.
INFO: Station role is root.
INFO: DNS and Domain name configured.
INFO: Mac address of device is 00:1d:a2:7f:77:e6
INFO: Completed Dot11Radio0 shutting.
INFO: Device set up done and time configured on device.
INFO: Run-config dumped.
INFO: AP is DHCP configured.
INFO: Hostname ap-b36-k03-002
INFO: Starts loading recovery image, takes time based on link speed.
ERROR: Device Response :: examining image...
%Error opening (Invalid IP address or hostname)archive download: takes 0 seconds
ERROR: Image Loading FAILURE.
INFO: Un-shut radio 1 done.
END: Migration Process Failure: Image Loading Failure.
It works fine with the Cisco upgrade software.
Overall Rating: 5 (1 ratings)
Trending Topics - Security & Network
