Upgrading the IOS on Cisco router 871W
Apr 5th, 2008
I am trying to upgrade the IOS on my Cisco 871w. I have the enterprise IOS which required me to upgrade the flash. Well since I swapped out the flash the router is booting up to the ROMMON prompt. How do I get the new IOS on to the router?
Tim
kmccourt Sun, 04/06/2008 - 00:34
Format the new flash and use the ROMMON tftpdnld command to download the new IOS image from a tftp server.
Essentially, you have to set the variables below and download via FE0, for example:
rommon 1 >IP_ADDRESS=192.168.1.10
rommon 2 >IP_SUBNET_MASK=255.255.255.0
rommon 3 >DEFAULT_GATEWAY=192.168.1.1
rommon 4 >TFTP_SERVER=192.168.1.20
rommon 5 >TFTP_FILE=c870-advipservicesk9-mz.124-15.T4.bin
rommon 6 >tftpdnld
Full instructions are at http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/rommon.html
timt976 Sun, 04/06/2008 - 10:47
rommon 2 > ip_address=192.168.10.200
rommon 3 > ip_subnet_mask=255.255.255.0
rommon 4 > default_gateway=192.168.10.1
rommon 5 > tftp_server=192.168.10.21
rommon 6 > tftp_file=c870-advipservicesk9-mz.124-15.XY2.bin
rommon 7 > tftpdnld
Missing or illegal ip address for variable IP_ADDRESS
Illegal IP address
I enter all the commands but I am still getting that error. Is there something else I need to do first? Like change the config register.
Richard Burts Sun, 04/06/2008 - 11:24
Tim
Try it again and this time put the commands into upper case rahter than lower case.
Rick
