EasyVPN routing issue!!
Apr 6th, 2008
Hi All,
I've a cisco 857 router with 12.4T IOS software.
I've configured the EasyVPN on it, and the reverse-route. the client can connect to it through the cisco VPN client. but when looking at the logging window at the vpn-client, i noticed these logs;
10:00:54.921 04/06/08 Sev=Warning/2 CVPND/0xE3400013
AddRoute failed to add a route: code 87
35 10:00:54.921 04/06/08 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: ac10ffff, Netmask: ffffffff, Interface: ac113165, Gateway: ac113165."
Note; all these IPs in the log are used as a private IPs
Also, I can ping the resorces at the EasyVPN server network from my client, but couldn't access other resources such as ftp, telnet. While on the another hand the servers on the servers side can access the remote vpn-client.
please your support.
irisrios Fri, 04/11/2008 - 09:03
This is just a cosmetic issue where a broadcast message can't get acroos this tunnel. This shouldn't affect your connectivity.
