ACE vs Radware WSD
Roble Mumin Sun, 04/13/2008 - 01:02
About two years ago i had a similar issue with Citrix Netscaler vs. Cisco ACE(CSM).
I don't think there is a doc showing the advantages of an ACE vs. the competitors in marketing lingo.
What i did was to check out the technical specs of the Netscaler Series and compare it vs. the ACE in terms of connection per second, SSL setups, throughput, general features and scalability of the product. I had to do an internal presentation to convince the management part. It is kind of annoying to do stuff like this as tech but it helps keeping the disfavored toys out of the system. :)
If you already have a lot of Cisco equipment, pointing out that sticking to a vendor will probably support the manageability/maintainability of the network could also be a feasible argument.
Roble
