CCM 4.1 Cannot add phone. gives error?
blackswans
When I try to add a phone it gives this error:
Error Information
An invalid parameter was passed during processing. (8)
Details:
Error No. -2147219960 (0x80040608):
CDBLException Dump: [Invalid parameter]
any idea?
5 Replies 5
Rajesh Revuru
Level 4
Level 4
Hello:
This looks like database replication issue between publisher and subscriber.
Login to your publiser, and run DBHelper.exe and see if the database replication between those two are good.
But I have only one call manager.
ip phone model you try to add and exact CUCM version??
javalenc
java
if this helps, please rate
It is 4.1, I tried to add 7911 and 12.
thats not the exact version, 4.1(2)?? 4.1(3)?? SRs??? ES????
do you have at least the minimum requirements for those phones??
Cisco Unified IP Phone 7906G and 7911G Release Notes for Firmware Release 7.2(3) for Cisco Unified CallManager 4.1
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cuipph/7906g_7911g/firmware/7_2_3/english/release/notes/11R723sc.html
javalenc
java
