04-06-2008 03:09 AM - edited 03-05-2019 10:13 PM
Is it possible when using the HSRP protocol, for host on different VLANs to use the same gateway address.
04-06-2008 03:10 AM
If u r going to use the same gateway address there will be no communication among u r vlans.
Mahmood
04-06-2008 05:17 AM
Hi Oladapo,
No, it isn't possible.
Different vlans should be different subnets.
In each subnet, you need to select a virtual gateway address from the respective subnet.
If you need help in configuring your HSRP load balancing, please give us more info about your environment and we will be able to help you.
Cheers:
Istvan
04-07-2008 05:44 AM
hi Istvan,
Thanks, i get it now. That is what i wanted to confirm, that each subnet needs it own virtual gateway address.
Cheers
Oladapo
