E902: package could not be installed. Error in installing application
Apr 6th, 2008
Hi All,
we try to deploy our first application(IPPhoneServicesTutorial)
we do it using designer 2.4.2.009 on application server cuae
2.4.2.009, and we get the following error:
we check the application server log and this is the result:
Full information as follows:
Source: mscorlib
Message: Value cannot be null.
Parameter name: path1
Stack Trace:
at System.IO.Path.Combine(String path1, String path2)
at
Metreos.ApplicationFramework.Assembler.Assembler.DetermineWSE3Path()
at Metreos.ApplicationFramework.Assembler.Assembler..cctor()
2008:04:07::04:57:29(04): Error: AM
Application 'IPPhoneServicesTutorial' installation failed:
Application IPPhoneServicesTutorial failed to load.
2008:04:07::04:57:35(10): Info: MCP Unable to connect to media
server Media1 (127.0.0.1)
2008:04:07::04:57:50(17): Info: MCP Unable to connect to media
2008:04:07::04:58:05(17): Info: MCP Unable to connect to media
2008:04:07::04:58:20(18): Info: MCP Unable to connect to media
note that the media server service always stoped automatically
aji_ece36 Fri, 06/12/2009 - 03:12
I am also getting the same error. I did one sample application in cuad. when i try to build my project the following error came:
Full error information as follows:
Source: mscorlib
Parameter name: path1Stack Trace: System.String Combine(System.String, System.String)
at Metreos.Max.Framework.ProjectBuilder.PackageApplication()
at Metreos.Max.Framework.MaxMainUtil.BuildProject(Int32& warningCount, Int32& errorCount)
at Metreos.Max.Framework.MaxMain.OnBuildProject()
Please help me regarding this.
Ajith
