Are these layer 1 or layer 2 error?
Apr 6th, 2008
I entered the following 2 commands, there is no input error on atm 0/0/0, only 92 crc, but there are lot of crc error on sh dsl atm 0/0/0, are these layer 1 or layer 2 error?
router#sh int atm 0/0/0
ATM0/0/0 is up, line protocol is up
Queueing strategy: Per VC Queueing
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
431559 packets input, 167730219 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 92 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
395828 packets output, 63240991 bytes, 0 underruns
router#sh dsl int atm 0/0/0
Interleave Fast Interleave Fast
Speed (kbps): 0 3008 0 512
Cells: 0 22134693 0 1794469949
Reed-Solomon EC: 0 0 136 75
CRC Errors: 0 10692 175 80
Header Errors: 0 26306 192 138
Total BER: 0E-0 4129E-8
Leakage Average BER: 0E-0 1908E-8
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sun, 04/06/2008 - 10:09
  • Hall of Fame,
    Founding Member
Layer 1 errors. The circuit is not very clean, but probably acceptable. Which DSL FW are you running, from show dsl interface ?
rleung2001 Sun, 04/06/2008 - 12:44
What is that header error? I thought it was the layer 2 header.
Init FW: init_AMR-R-2.5.042_no_bist.bin
Operation FW: AMR-R-2.5.042.bin
FW Source: embedded
FW Version: 2.5.42
